Re: 140 Steering arm replacement
rust makes rust that makes rust, try chipping as much out as possible, wearing your safety glasses of course, those arms are pretty thick, inspect it and see if its a project you really want to get into, you will have to pull the power head, and alot more for this job to be done correctly, the lu/ will have to be dropped, algong with the adapter plate and lower pan as the upper mount is there, then the question of the nut, and bushings, the mid section will only be in your way so put it to the side as well. this is not a hour project, and corrosion will be a factor especially around the adapter plate and mounts<br /><br />keep us infoed, and good luck<br />r
