goblerblaster
- Joined
- Dec 26, 2011
- 180
I got a 9.9 Evinrude model E10rcid 1981 model that had a 15 hp evinrude carb on it. This carb was gunked up so I took it apart, soaked it in Berrymans carb cleaner bucket, put on a carb kit , and re-installed. The motor would start but only run with the choke pulled out. I repeated the cleaning process and had the same result. I got a 9.9 carb from a guy that posts on here , cleaned it and put a new carb kit in it- I did pull the two knock in plugs in the carb to make sure no gunk was hiding behind them- and put it on.... same result. Really Hard to start and then only run with the choke out.
I went back to the 15 hp carb, cleaned it again, re-installed...same result. Then I figured it must be fuel pump or fuel line, so I took the fuel pump off a good running 15 hp Evinrude, replaced the fuel connector that the gas line from the tank connects to, replaced the 5/16 fuel line from the connector to the fuel pump, and replaced the fuel line from the fuel pump to the carb with the new yellow line that allows you to see gas is actually in the line. When I hooked everything up and pumped the fuel line primer bulb I could not see gas in the line that goes to the carb. I took off the line at the carb and pumped the bulb and gas squirted out. I reconnected the fuel line to the carb and after about 15 pulls finally got the motor to start. It would still only run with the choke about 1/3rd of the way out. I dosed the gas can with a heavy round of SeaFoam and kept it running for about 15 minutes by feathering the throttle and pushing the choke in and out. When it died, I had a lot of pulling to no avail so I took the fuel line off the carb, pumped the bulb and gas squirted out of the fuel line. I reconnected the line and the motor started on the second pull. I kept it running at fairly high rpm and started backing out the lean/rich mixture knob.
Once I got it backed off to about 2 3/4 turns from lighltey seated, it finally would run without the choke being out any at all. I let it run for 45 minutes at varying rpm and it finally seemed to be idling pretty good and reving up with minimal hesitation. I killed the motor with the kill button and immediatly tried to restart. NOTHING again.
I am getting good spark, new plugs and gap set correctly. When it is running it does not miss or sputter.
Could this be some type of vapor lock? It seems that disconnecting the fuel line at the carb has an impact on it starting. Also, It seemed weird to me that when I put the fuel pump on and pumped the fuel line bulb- no gas came through the line going to the carb until I disconnected the line at the carb and then re-installed it. I know this carb is not supposed to be vented, but could it be that the packing washer around the rich/lean needle is too tight and not allowing any air in since I had to back it off 2 3/4 turns to get it to run without the choke being out? How come it will run for 45 minutes and not restart within 20 seconds of me killing it ???
Any suggestions or ideas would be appreciated. This is not the first one of these I have worked on and I have rebuilt a bunch of carbs...this one has got my goat !!!
