Re: 15 hp - no compression on one side
Bought a used '93 - 15 hp Johnson, supposed to be low hours and hardly used. It was a sight unseen private deal and I got taken to the cleaners. Got the motor home, besides being very dirty it has no compression on the bottom cylinder. Called the seller back and he swears it ran great last time he used it but it has been sitting for 2 years since being run. OK, I'm a big boy and it was sold as is. I've rebuilt sled engines before but they have removable cylinders. My question is if you need to remove the entire power head out of the chassis or can you strip it down as is. Looks like you can remove the lower engine covers and get at all the bolts. Not quite sure how to proceed. Any advise would be appreciated. Thanks.
I rebuild 15s regularly, have 1981 and 1985 models myself. Pull the powerhead and rebuild it, could have a hole in the bottom piston. At the very least the rings are completely stuck or broken. First, get an OMC service manual from ebay, any year 1977-1993 will work. You can get all necessary parts from Seaway Marine in Seattle at good prices. You could pull the head first, as someone advised, to see what the problem is.
Some advice: the 15 is unusual, was rated 15 hp at 6500 RPM with normal operating range 6000-7000 RPM instead of 5000-6000. Run 25:1 oil, not 50:1 (unless you're trolling or running a lot a low speed), use only Evinrude, Yamaha, Mercury, Suzuki, or Castrol oil, TCW-3.
Good compression is 120-130 psi. I would rebuild any motor with compression as low as 100 psi, because blow-by is surely occuring and you're losing a lot of acceleration.
