I have just bought a 92 Johnson Fast Strike 150hp V-6 (Ser # G02653323)It sat for 3 to 4 years. It started the first time I tried it. My problem is at wide open throttle. It stumbles, and will not go above 4500RPM. I can hit the choke and she will start to pick back up. I just realize the chock is actually a fuel boost, so that tells me its starving for fuel. It has VRO2 oil injection system. What do I need to do to get the engine back to like new. I did put in new plugs.
<br />Also the trim will not raise the motor under throttle to help me come up plain. Is this normal, or is it weak? I thought it should make some adjustments while running. <br /><br />Thanks. <br />A cop that needs to FISH.
