crazy charlie
- Joined
- May 22, 2003
- 5,732
Need some help guys.Duplicate problem that I had repaired last year.Tech that fixed it said it was a bad ignition switch________. I should have listened better at the time.Same sequence of events.1995 150 Ocean pro.Running great all spring.Idling up canal,turned ignition off to hear some music we were passing.Went to turn ignition switch back on and NOTHING.Heard a slight selenoid click when turning key.Heard a very dull buzz coming from the tilt selenoids when I tried to tilt.Nothing. I checked all connections,batteries,starter,etc,battery switch.The battery switch was last and everything worked after checking those connections.Started right up but the sound was obvious to me that it was only running on 3 cyls.Just like last year.Anyone know the right name of the part that I need???I am anticipating having a hard time getting a hold of the same tech.Maybe some help with a diagram so I know where to look.Any assistance would be appreciated.Thanks Charlie
