Re: 1500 distributor cap electrode replacement
I take it that part of the old one is still in there, right?<br /><br />It's probably gunked in place. You could spray some carb cleaner on it and that might help loosen it up. You could also, carefully, drill a small hole in it so you could run a screw down enough to catch it and pull it out.<br /><br />There's a spring behind it, try not to damage it, or drill too far in and damage the cap.<br /><br />HTH.........ed
