Re: 1500 thermostat question?
Anthony, The teletale is a stream that exits out the back right bottom of the lower cowling of the motor. Right above where it says "1150". If you take off the wrap cowling,you should see a hose that runs from in between spark plug no. 1 and 2, down to the bottom of the cowling. Water will also come out the gratings just above the prop and antiventilation plate, as well as out the square holes in the back of the motor, just below where it says 1150.
