Re: 150HP Force 1991 tilt/trim question
before tapping down inspect the rubber grommet and bronze scraper ring. make sure both are clean. inspect recess and make sure it is also clean. the bronze rings fits inside the rubber grommet. after tapping back down into place take a punch and mark four small indents to hold it in place. If you do not have ounch then take a hardened concrete nail and sharpen it into a chisel point approx 1/8" wide. rotate your new marks 45 degrees from original and try to copy the original locations and depths. if you punch to hard you chip out aluminum and if you punch too lightly then retaining plug won't stay in.
