Ok I would like to thank everyone ahead of time for your input. I have a 1974 1500 incline 150hp. Last year I restored a 1976 15ft checkmate and put this motor on it. After a couple of months the motor started fouling plugs I could replace two and it would blow them all out. Today I started the boat from the winter it started fine just like new after letting it run for a few minutes I pulled one plug from each carb the top two were fine the bottom plug was covered in oil. I assume there is a problem with that carb. So all things are running through my mind is that the reason I wasn't getting the speed I was hoping for. I would top out at 43mph on a gps. Im running a 19p prop. Also I forgot to mention the last time I went out last year I put 93 octane gas in it no fouled plugs that day. Does anyone have any suggestions? I am a member on the checkmate site and others are getting up to 60mph with less motor than I have. Again thank you for your suggestions and or help.
