After a couple of weeks of hemming, hawing and researching, I've decided to start to tear into my 16' Calglass project. It's basically a basket case as it is now, and since this is my first boat/marine project I won't feel bad if I botch it.
See the original post about this boat here: http://forums.iboats.com/showthread.php?t=321391
I've done some searching around the area to see what's available, and have decided that people are far too optomistic about what their boats are really worth. I can get something complete for 3-4k, but even my newbie eyes can pick out many major flaws with all of them - like the mid 80's 18' I looked at last weekend. Soft floor through out, bad wiring on the engine, air intake and blower hoses disconnected or missing all together, suspect wiring for a lot of the electrics. And this one was $5k...
So, I'll undertake getting my 16' runabout seaworthy once again. At the very worst, I sink 3 or 4 hundred into the floor and transom and then discover it's too far gone and send it out to the recycler, I can handle that.
Started step one this afternoon, tearing out the floor. Before actually pulling it up I decided to drill a few holes to see what the state of affairs underneath was. Went at the floor with a 3/4" blade bit, went through that rotten floor like it wasn't even there, and then darn near lost the bit in the cavity underneath!
Couldn't even touch the foam in there with my finger...
So I figure 'Great, at least it'll make it easy to remove the foam because it's completely decayed'.
So, time to start pulling up the floor. I discovered the easiest way to do it was with a 5" angle grinder and a 3/32" stainless blade. Cut through the old 'glass like butter, but once it hit wood it would stop.
took about 15 minutes to get the front section of floor cut from the hull, and the fiberglass joint between the front and rear floor sections cut through to the wood.
About 2 minutes of poking and prying with a prybar and scrapper and the front section came right up.
Then I discovered my foam was actually pretty good, seemed intact and not water logged at all, what there was of it - only filled about half the cavity.
Then I discovered the underside of the floor is completely bare, no glass at all.
