Chris Stydom
Thread starter- Joined
- Sep 29, 2018
- 4
Hi All
I have a 175 V6 Model J175GLERA. Changed all the gear box seals in the lower unit as I had water in my oil. After reinstalling it all my starboard side Bank is getting extremely hot. 110celcius + and going into overheat alarm. Port side maintaining around 70celcius. This is all while running on bunny ears on the trailer. I did try swop the thermostats around with no change. I also ran the unit without the starboard thermostat and I did see after a minute or so water circulating in the starboard block.
I also changed my plugs from Champion to NGK not sure if This would have changed anything?
I did manually feed water in through the thermostat opening to confirm that there is no blockage.
I read the recommendations about the deflectors mentioned earlier. Would this be a similar issue to look at in my unit? Does this mean I need to remove the head?
Thanks in advance for any direction
