I started this project a while back and I got busy with college and work. I have a long ways to go, in short amount of time. But with a lot of Faith and determination I will have it in the water by May. I inherited this boat from my grandfather who died from brain cancer in 2010, I grew up going out on this boat with him and it has a lot of sentimental value to me. I want to do everything right and not take any short cuts. This is my first restoration though so sorry, but I will probably have a lot of questions.
So, the boat is a 17ft 198? Shoalwater flat bottom skiff. The main deck was rotten so I cut all of the fiberglass out and removed the rotten wood and saturated foam. I ground all of the gel coat down to the fiberglass and i think that i have it ready to start putting it back together but correct me if I'm wrong. I have already cut out all of the wood to put back in, but I was wondering if I need to put the foam back in? And if I should tape the plywood with 1708 and then go over it with 1.5CSM or how I should go about it? I am planning on using polyester resin, is this a good idea?
These pictures are from when I had just gotten the foam out, I have since ground the tab on the side off and all of the gelcoat. I also tested the runners and the foam in those is dry.
