Re: 18 hp Evinrude 57-58
Alright..Today's events. After a sleepless night of anticipation I got up early and started to look over the two motors. First thing I noticed was that the "all together" motor had a broken transom mount. At that point I decided that I would have one motor. Considering that the parts motor may or may not be all there. 2 hrs later I had it remounted on the good transom mount. I only took it loose at the bottom and the top bushings. Then on to the lower unit. To my suprise the parts motor had a new impeller. I also ran some light weight oil through the motor to clean out any junk. I cleaned the old water pump and moved the impeller. Then replaced the O rings at the water pump housing and the top of the drive shaft. When replacing the lower unit I found that the shift linkage bolt was stripped. I pulled the lower unit back off and mounted the linkage to the shift rod on the lower unit with a longer bolt and a nut. Then put it back on and tighted the top linkage. Piece of cake! Along the way I did check shift operation, emptied the light weight oil and added new lower unit oil.
Finally on to compression. Using a cheap compression tester, and pulling 3 times I acheived between 95 and 100 on both cylinders. Looked pretty even. I checked fire on both plugs and it was hot and blue/white. Depending on how hard I pulled.
While looking at the carb I noticed that the body boss gasket was on the high speed needle. Hahaha. I realized immediatley I better pull the carb apart and see what they had done. It was very clean..Must have been soaked. Luckily the body boss gasket was the only one out of place. I threw on the carb, replaced the fuel lines, cleaned the sediment bowl, used the filter from the parts motor since this one was invisible. To my disappointment some yelled the dinner call and I was done for the day.
Tomorrow, points, fuel, start attempt. If the coils look cracked, I also have a brand new set from the parts motor. Anything I'm missing? Starting tips for this beast would be helpfull.. Thanks everyone.
