18' Starcraft Starchief OB Rebuild
Gibbles
Re: 18' Starcraft Starchief OB Rebuild
Thanks, this will be the Party/fishing/camper boat :D
And I have been looking at pedestal seats with the removable mounts, but it looks like they need to go about 4in below the deck, and where I want to mount the seats I may not have that much space, but I'll have to measure to be sure.
And I'm looking to keep the seats to the sides as much as I can, to keep the walk way clear.
If I had a V Hull I'm sure it would be no problem :facepalm:
if not enough space, I'll go for something like this
http://www.ebay.com/itm/SWIVL-EZE-ECONOMY-FIXED-HEIGHT-SEAT-PEDESTAL-13-3954-/250698486475?pt=Boat_Parts_Accessories_Gear&hash=item3a5ecb52cb&vxp=mtr
Also I have to figure out how high I want them, I found swivl-eze has some nice affordable sets on ebay, but I might end up being a little limited by how high I can go.
Example here: http://www.ebay.com/itm/BOAT-SEAT-SWIVL-EZE-3-PC-OFFSET-PEDESTAL-SET-13-GAL-/271041926826?_trksid=e11012.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D10%26pmod%3D280946681173%26ps%3D63%26clkid%3D1529749193971704879&_qi=RTM839985
time to mock up the windshield and see how high I need.
if the idea works out I plan on having 5 or 6 mounting locations
jlwood3
Nice project! These are great boats. Here is a pic of how I did my consoles.
Gibbles
That looks great, and looks much better than what I was thinking.
One question, how did you route the steering cable, and what did you do on the inside of the cabin space where the consoles were?
Thanks!
Gibbles
Also I dropped a Franklin on a soda blaster and a 50lb bag
I cleaned up the inside a bit more, paying attention to areas that will stay bare metal/not covered.
And made a bit old mess, but with that much baking soda there will not be any funny smells! :D
I need another 50lb bag to touch up the splash well.
Also I took apart one of the consoles for a good template and then got the cabin walls cut out and fit.
I tried to upload a bunch of pictures but it seems photobucket is having some issues today :(
North Beach
I guess they are taking turns on us. Yesterday my pics were all messed up and couldn't upload anything. Today everything's fine????
Gibbles
Seems to be fixed now, but it gave me an error even trying to load their home page :(
Gibbles
The 1963 consoles
Gibbles
Taken apart for a template
Gibbles
Transom in (mostly)
Used rivets coated in 5200 for transom cap
jbcurt00
Nice job on the cabin wall!
@Transom too.
Gibbles
Had a bit of damage to the center part of the transom cap
lots of 5200, and will be covered later on
Prev owner had trim tabs, then removed them... then filled the holes with rusty steel screws coated in blue gasket maker..
Filled with rivet coated with 5200, then fulled with more 5200
Gibbles
Did same with other holes for now.
Gibbles
Also on the cabin wall, I used 3/4in and the scrap from the flooring was just the right size.
The orig consoles seem to be structural, so I'm keeping that in mind while I'm putting everything together.
jbcurt00
Thanks! and that took more thought on how to extend than it should of :)
Extend? Wider out from the gunwale? To move the door over some? Based on the way it looks in relationship to the seat bases in the cabin, looks like you've got the door centered & just about right for the seat bases.
Looks like you nailed it 1st time & it only took 10-15min ;) But we don't have to tell anyone any different :facepalm:
Gibbles
Extend height from torn apart console piece ;) (silly 1963 designers had an open cabin; fixing that, dern hippies)
And once I had one figured out, it was an easy copy onto the other board, that one took minutes! :D
dozerII
Great job Gib, coming along nicely. It is incredible how many holes the transom on some of these old boats can gain over the years. The 18 SS I did, had an extra 25 if I remember correctly, all from transducers, wires, hoses, and pitot tubes.
Gibbles
There are even more that sit under the transom plate. :facepalm:
For those I used 5200 and when the transom was bolted in it squished it down real nice, then covered with wax paper to get a flat surface.
Also I found one loose rivet, looks to of been caused by the trailer bunks.
I'm going to try and rebuck the rivet using an air chisel with a modified bit.
When I applied the gluvit I only mixed up half of the can, got everything that's under the rear floors and stopped there because of this rivet (sit's under the starboard front bench, end rivet for a rib).
Gibbles
This weekend I'll see about getting the transom drain tubes installed, and some more soda for the blaster.
That's working really well, but I'm going through the stuff really fast... $35 per 50lb bag :(
Went through two bags so far.
