Motor Boater Bill
- Joined
- Jan 29, 2005
- 488
I just got a 1954 RD-16 25 hp Johnson, and I know nothing about it's history, so I'm starting from scratch. No idea how long it has been sitting, but it is not frozen, the LU shifts properly, so far so good. Turning it by hand, the lower cylinder has obvious compression, but the upper has almost none. As I turn the flywheel, I hear the air excape as the cylinder rises. I have not measured the compression yet but the problem is obvious. Somewhere I seem to have seen a reference to compression release on some Big Twins, so before I tear into this I thought I should ask--did this model have compression release? If so, how can I check it out? And if there is no compression release, what's my next step in investigating this?
