Mark Fletcher
Thread starter- Joined
- Jun 28, 2012
- 30
Hi all, new member here. I have the above engine and I forgot to winterize it 2 years ago. I just found out a few days ago. :redface:
Cleaned the carb, tried to start and water in the top cylinder and zero compression. Bottom had 50 psi. It started and ran, but only on one cylinder.
I sanded the head and replaced the gasket. No water that I could tell, but still no compression.
I removed the aluminum exhaust baffle plate and there was a couple small holes. I patched with JB Weld and re -installed it.
One of my first steps was to check spark and it does spark. The coils look good through the hole in the flywheel. The points are set to .020" and are not pitted.
Upon checking the spark some more, it looks like it may be weak but I don't know!
Upon checking the compression again, I don't get a reading on either cylinder.
I checked the gauge with a lawn mower and no reading on it either. It just bounces and will not stay. I checked it on my dirtbike and it has 132psi and the release valve works on the gauge. So I'm not sure what's going on there.
The good 'ol boy thumb over the hole method implies that there is good compression.
I'm stumped! I've never worked on a boat engine before and I don't know what else to do. How do I test the coils?
I know many of you probably don't care about an old worn out Evinrude, but I really like the engine. It pushes my 11' flat bottom jon boat great! Please help!
