1957 35HP Big Twin (hitting hard Knocking)
Joe Reeves
Re: 1957 35HP Big Twin (hitting hard Knocking)
(Jumping Out Of Gear - Manual Type)
(J. Reeves)
This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".
Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.
When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.
The lobes of the dog and gears are precisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are precisely machined with sharp angles!
Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those precisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.
Some boaters with manual shift engines have the mistaken belief that shifting slowly is taking it easy on all of the shifting components..... Wrong! Shifting slowly allows those precisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
bigballerg
I believe it is clutch dog as well. It is exactly what sounds like you guys are all describing. Thanks for all the input and now to hunt for a 1957 35HP Big Twin dog and how to instal the damn thing... the fun begins....
RogersJetboat454
Chris, is this model reversible if he cannot find a new one?
Marine engine is showing 10+ in stock. He would have a hard time NOT finding a new one. May still currently be in production.
kfa4303
Banned
While they can be a little pricey, the installation is pretty easy. Although you do have to open up the gear case, which means you'll need to reseal it. You can get a reseal kit right here at iboats for about $25. You'll also need a tube of 3M 847 gasket maker, which you can find online.
HighTrim
Sure is, good point Willy. Reverse may jump out, but you are usually only in reverse for a short period at low RPMS anyways.
bigballerg
is it easy to replace this dog? Take down lower unit, then take out prop and take out dog, then replace etc..? Reversible sounds good to me....
HighTrim
Well if you are going to do routine maintainance, such as water pump, regreasing the driveshaft splines, changing the ds splines oring, full reseal, etc... you will need to drop the gearcase, invert it in a stand to work on, pull the prop, remove the skeg screws, remove the skeg, pull the prop shaft assembly out, slide gears and such off to be able to slide off dog, then reverse order. As Willy stated, you may be able to flip your dog if the reverse lobes are still good. Up to you. If the only work you need to do is remove the dog, you can invert the motor and remove the skeg without dropping the gearcase. I have done it but I usually like to check into other things while Im in there so I usually drop the gearcase.
Bare minimum, if your seals are ok and not leaking, you will still need more spaghetti seal to reseal the skeg, and some sealer for both the spaghetti seal and skeg screws. If the seals are questionable, now is the perfect time to reseal the gearcase.
The following will help with this.
Asm_LU.jpgService_Bullitin_197_Gearcase_Leak_Prevention_5.jpgService_Bullitin_197_Gearcase_Leak_Prevention_5b.jpg
bigballerg
ok, thanks for the info. Let me get this all worked in my head... Having a hard time visualizing "invert the motor and remove the skeg without dropping the gearcase" I have to remove entire lower unit, then UPSIDE DOWN remove SKEG and the dog will be right there? Sorry for not fully getting it...
HighTrim
Sorry I made it a little confusing.
IF you have recently serviced the motor, and know all else is fine, I have flipped the entire motor upside down, and simply removed the skeg from the gearcase to access the gears/dog. I probably should not have even mentioned this option, as you should probably drop the gearcase to inspect the rest of the system, and do other routine maintainance while you are in there.
bigballerg
OH, I see... Yes, it has been serviced, new impeller, etc... So, I'm liking your plan. there are 9 total screw plus drain screw. I can tilt the motor quit a bit to be able to work on that area. Does it have to be fully upside down or can I work on it tilted? Will anything just fall down?
nwcove
http://www.marineengine.com/parts/vintage-ev]Vintage Evinrude Johnson Outboard Parts & Diagrams - Catalog 377025[/url]
if you go that route, as mentioned , you will need the spaghetti seal (#16), an i would also replace the o-ring (#39). jmo
( the link i gave isnt working correctly, but on the left hand side, click on page 16 for the exploded view, and page 17 for the part numbers)
HighTrim
You will need the motor completely upside down. You will never get it back together unless it is. Drain the oil before hand of course, and ensure there is no water in the exhaust cavity that will run towards the powerhead!
bigballerg
Understood... I read a post that the prop can cause this craziness also? Since I put a new prop in I'm going to try it out at lake tomorrow. I am sure the same issues are going to happen, BUT what the hell... will advise my findings... Might just lose another prop :) Thanks!!
nwcove
if at all possible, plz video with sound! still not sure how you could loose a prop, but sh#^ happens. lol
HighTrim
If your prop has a spun hub, it will rev up when the RPMS increase, but the boat will not accelerate. A bit of a different issue from what you described.
Chinewalker
Running it more with a bad clutch dog can ruin the gears. The clutch dog is considered sacrificial - to a point. Continuing to run a rounded out dog will eventually round out the gear lugs, too, meaning even a new clutch dog won't get full grip... And, as said above, a slipping prop hub will not give the symptoms you noted.
bigballerg
OK, tested... CLUTCH DOG it is right??
