1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
F_R
Re: 1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
Well, if I am seeing what I think I'm seeing, you already have a detachable fuel connector clipped to the motor. That is the only difficult part to find. Now all you have to do is as you suggest, clamp a hose to it. If you want a dual-use tank for this and an OMC, simply make up a short adapter hose with OMC motor side connector on one end and your Oliver tank side connector on the other end..
coolbri70
made a video of the fitting so you can see it better
coolbri70
i want to try it out, do i need a primer hose or can i put a temporary gas tank uphill to feed gas for test starting? siphon feed? for bench testing
coolbri70
i was turning the flywheel by hand, good pic of spark just before the end
Willyclay
I watched your video and, yes, that fuel hose connector is very similar to an air compressor connector. A check-ball with O-ring acts like a valve inside the fitting so it should not leak when removed. Slide the moveable sleeve and pull the fitting off. You will need primer-ball hose to get the carburetor bowl filled when running it on a boat. For testing, I have used a turkey baster(sp?) to fill the bowl and then run an engine with a siphon hose raised above the engine. Good luck!
EDIT: I could not quite make out in the pictures what is stamped on your armature plate. It appears to say the points should be set at .018 inch gap.
coolbri70
got the day off so i been working:D
F_R
I just looked at your video of the fuel connector. You show yourself moving the sleeve back and forth. When you pull on it, the connector should unlatch and just pull off----as you said, similar to an air hose. You are so fortunate that you have that connector. Trying to find a replacement would be about equal to finding a set of chicken fangs.
As I said earlier, just attach a hose and you are in business.
I haven't gotten to the other videos yet.
coolbri70
ok thanks, now i get itView attachment 180227:embarassed: sometimes i aint too bright:facepalm:
coolbri70
i took the motor to work with me and left it so i can work on it during down time. pulled the lower unit checked the impeller, the rubber is still soft and no dryrot,View attachment 180489View attachment 180490 then i put air to the fill hole and oil squirted out around the shift linkage rod, so im thinking thats my leak, maybe some seals:confused:
coolbri70
worked on the lower unit today, took the linkage out replaced the seal, then i couldnt thead the rod back into the shift fork so i had to open the case, i didn't want to as i didn't have a gasket and of course it ripped so i cut one from a roll of felpro i hadView attachment 180651View attachment 180652View attachment 180653View attachment 180654View attachment 180655 got it sealed up and back together, just need to bolt it back on
woodsailboat
That fuel hook up is the same that's on my 88 suzuki, and yes the end that goes on the tank hose is already on. Pull the collar on the fitting back and wriggle it and it should come off.
rvcat
Coolbri. Hello I just joined the forum, Noticed your post on the 1958 Wizzard 5 1/2 hp. I just recently picked up the same outboard, I collect vintage snowmobiles, and in my last deal I was given 7 old outboards. I think I have a new hobby. I haven't worked on the snowmobile yet, but I've spent time on 2 of the outboards. The 58 wizzard (Oliver) seems like a very well built motor, I have to replace the impeller and some other parts that were missing. So far I've located what I need, can't wait to hear it run. Good luck on yours ,I think I'm going to have to get a small boat to try my New toys Thans Joe
coolbri70
Welcome to the forums, if you need help just ask the forums somebody knows:D i was looking for a kicker motor for my boat, and saw this non descript ad for a 5 1/2 hp gas boat motor, it was only $75 so i sent a response of intrest to the ad, he didn't get back to me i found a little evinrude that was perfect for a kicker:joyous:, after i bought that, he calls wanting to know if i still want the motor:facepalm: i figured for the price i would go look, he had since posted pics so i researched and knew what i was looking at when i went, the seller didnt know it was western auto till i showed him the tag. i will get this going before spring, then i will be the idiot at the launch with 3 outboards on my transom:rolleyes: 2 new ones to test out:)
coolbri70
todays progress View attachment 180881View attachment 180882 filled it with lube, put it back on:cool: the rubber gasket for the water tube had previously been mashed into the top of the water pump half blocking the tube, i made a new one from a piece of rubber hose, after a few dozen trys i got it lined up and on, it was hard to see the tube and pump as the case closes:rolleyes:
