1959 Johnson V50 Outboard Oil Vent?
rhayes2849
Thanks to all in advance for your help. I have some kind of oil coming out of this small hole that says fill with hypoid oil, and I am not sure if it should be, please help. Is water getting into my lower end?
see pic
There is a larger picture at www.unitedsteppers.com/songs/2.jpg
I love the water!
1946Zephyr
Re: 1959 Johnson V50 Outboard Oil Vent?
That is likely a drain hole for a cavity in your lower unit. If you can, make sure it stays clean and free and doesn't get plugged up. The oil you see coming out of it, is unburnt oil from the engine, that has settled in the lower unit. This is very common.:cool:
