ssdale
Starmada Splash of the Year 2016
Thread starter- Joined
- Nov 4, 2011
- 285
Re: 1959 Starcraft - About to start restoration
Had a little time this afternoon (as another round of snow) fell to work on the StarCraft. Paintd the floatation box and forward hull. Finished sanding the dash and am trying to get the new bow support just right at the bow to accommodate the anchor assembly and everything else. Test fitting to find the sweet spot to fasten the dash. The dash is a real structural component of this boat and dictates how the final bow sheet metal fits (or doesn't).
I reused the bow plywood as it was in decent condition. Soaked it up real good with primer. Plus it fit under the bow sheet metal like a glove.
The tricky part is that the bow plywood all needs to be fastened to the oak gunwales before you can attach the bow sheet metal. So once the plywood is attached, there is no re-positioning to get a better fit for the sheet metal. The gunwales are not quite exactly the same curve as the sheet metal, but pretty close. Any advice would be appreciated!
Dreamin of spring,
Dale
Dreamin of spring,
Dale
