Re: 1960 evinrude larkII 40hp
There is only ONE position where the shift rods fit properly into the coupler, and that is where the recess in the ends of the shift rods line up with the bolt holes in the coupler. Only in that position will the coupler bolts easily screw into the coupler. If the recess in the end of the shift rod doesn't line up with the bolt hole, you will strip the threads on the bolt and you will almost have to force the bolt in. If you are sure the shift rods are properly installed in the coupler and it's still not shifting, then you either have play in the upper shift rod, or the Phillips pivot pin at the bottom of the lower unit is not engaged in the shift yoke, as said before.
