Re: 1960's 13' MFG carefree Rebuild (complete noob, i know nothing about this!)
I use Isothalic 404 Polyester tooling resin from UScomposites.com, just like you said to use. so if i dont use wax, how long will it take to cure to the point of being paintable? I know thats a while from now, and i have alot of prep work to do, but i'm just wondering. I was watching a show on discovery channel called American hot rod, and they were restoring a fiberglass corvette. The body work guys used these long sanding boards, what are those called? It was like 2 feet long and you clamp sandpaper to it. I'd like to use something like that so that my sanding job will be a consistent level across, as to make the high spots level with the rest of the boat. Thanks for your support guys
Oh btw WOG, i have one gallon of resin left and its called 435 Standard Polyester Layup Resin. I got it because it was cheaper then the 404, i can use this the same way, right?
