BoatgoatmfgVT
Thread starter- Joined
- Jul 3, 2012
- 218
Re: 1960's 13' MFG carefree Rebuild (complete noob, i know nothing about this!)
I'm glad i could help you out with that, nice to see someone benefiting from my Diy work! Yep, that should work great for you greenbush, thats the layup pattern i used. Make sure you grind a nice taper 2 inches out from either side of the cap fusion seam.The transom cap repair is really nice, I was getting ideas on how to do mine, I cut my top in a very similar manor, and played with idea's on how to support and glass it from underneath. Your solution is what I will do too. I planned to use the wood underneath and glass it all in, leaving the top for cosmetic mostly. After I do the bottom side with wood and glass, I will do One layer of CSM followed by a layer of 1708 on top finished with more CSM, then grind, fare, sand, prime and paint. Should be very strong once done. Thanks for putting the picture up, they helped me a bunch.
