I have a 60's evinrude skitwin 33 my original gearcase froze and i was lucky enough to find another on ebay. i mixed and matched all the good parts into one, but cant seem to stop the oil leaks. this last bout i sealed every seal with a rubberized epoxy used on aircraft. the prop seal doesnt seem to be leaking so it must be the upper shaft seal, or the shifter rod.. i pressurized the case and couldnt find leaks. but when i run it my trough has a ton of frothy oily residue. the fuel is 50:1 is this enough oil to froth it up?? i didnt check the oil for water yet just saw the foam and gave up..
1. does anyone know if there is a seal in the shifter rod its buried so far down in the gearcase i cant tell. if so is there a p/n?
2. Are the upper seals available?? does anyone have P/N??
Thanks
Barry
Thanks
Barry
