Marioleonard
Thread starter- Joined
- Apr 27, 2009
- 68
Hey guys do you know what wire from the mangeto ignition that I use to hook up the tack. Is it the wire on the outside of the magneto box that goes to the juction box with all the wires? I know that there are two black wires on goes to the magneto box on the bolt that's out it and then goes to the coil in side the magento box. the other black wire goes to a ground on the block and the brown wire it the temp light. The white wire goes to the kill switch. what wire do i hook a tack up to? or do I add a wire and to were?
