1962 johnson 40 hp RK-24-L Needs a voltage regulator
todd281
I just got this motor from a estate sale. It is in real good shape including the control box. The voltage regulator is missing , I have read through the forums, and see that there are a few options. Does anyone have the part numbers for the regulator? maybe the other options? or a work around? [I read something about a Harley regulator replacement.] Most of the posts were a few years old, so I thought perhaps something new has come up . thanks for any replies
todd281
I am in upstate NY. This motor has the electric shift and I am concerned about it running the battery dead while on the water. if it were the manual shift I would not bother with the generator. I am unsure as to how much draw the magnets put on the battery. How long could one use it on the water on just a fully charged battery?
hardwater fisherman
I dont think that motor is electric shift. In the parts breakdown it shows a shift rod and shift lever, which would indicate manual shift. Sorry I was looking at wrong model it is an electric shift.
Honorary Supreme Mariner
There will be constant draw of about 2 amps when in gear.
Vic.S
I think you must be looking at the wrong diagram. There were electric and manual shift versions of the 40hp
I thought they defaulted to forward gear when no power was applied to the coils so there's only a current draw when in neutral or reverse. ???? Or is that only the hydro-electric shift?
NO, NO---The RK models are electric shift and are not to be confused with HYDRO-ELECTRIC shift.---The HYDRO-ELECTRIC was never ever used on the 40 hp RK models !
Faztbullet
I have been told that a regulator off a Ford tractor will interchange...
todd281
I will purchase the Harley regulator that F_R listed. I am thinking of mounting it under the cowl, but I am wondering about the effects of vibration and heat on that regulator. Also, I was just wondering what kind of time frame I was looking at as far as running it without the generator hooked up . thanks for all the input
Time depends on the size / condition of your battery.-------Consult with your local garage / battery experts.
F_R
And did whoever told you that say exactly what regulator off what Ford Tractor? I'm not disputing the statement, just looking for verification. I've looked high and low for a suitable replacement, without much success, other than the Harley. And yes, I did check Tractor Supply.
F_R
Ever see a Harley run? Talk about vibration! Mount yours on the outer shell and vibration will be at a minimum. In fact, that is where OMC mounted them in later years--below the carburetor. Needless to say, they were sealed.
Seem to recall my 1940 Plymouth had a voltage regulator that " looked " just like the voltage regulator needed here.----But we know about stuff that looks the same !---I believe that in upstate New York you should be able to find a used regulator for your motor !
todd281
OK, I finally got the Harley 3 wire regulator , I am assuming the wiring goes as follows; red to "A" , yellow to "F" , and black to ground . Then another wire from "A" to the battery through the key switch . Sound about right? If not please let me know, as I don't want to burn anything up or short something out. Thanks for all the help , I'm hoping soon to get her out on the water.
oldboat1
Check the "secret files" up at the top of the forum -- link to Mastertech's wiring diagrams. Believe there is one for your motor (including the voltage regulator).
todd281
Yea that wiring diagram is for as Johnson wired them new. As I replaced the regulator with one that is solid state made for a Harley Sportster , as recommended by F_R , I need to know the proper way of wiring it into the system . thanks for the reply
