1963 Evinrude 40 h.p. stalling
moose54
I baught my frist boat a 1963 15ft duo with a evinrude 40 horse it has sat for a couple years. i tred starting it it wouldent run so i rebuilt the carb and now it will only run for about a minute or so i have gotten it to go into gear forword and reverse. when it does run it idel then rev up and stall. not to sure what to do next. any ideas? im also new to boating.
messed around with it today noticed that it was reving up on its own before it would stall.
1rawdawg007
Re: 1963 Evinrude 40 h.p. stalling
Hello and welcome.
Sounds like several possiblities to my feeble mind. Im not an expert.
Check fuel bulb and see that it stays fairly firm after priming. Make sure tank vent is open! Then...
Check every fuel line on tank and motor for fuel line cracks or loose connections at all attachment points and bends. With the extra pressure of the bulb pump, small leaks can be discovered sometimes..
Pull spark plugs, inspect and do a compression test on the motor.
Does it start right away after dieing? or does it have to be primed by primer bulb again?
F_R
Honorary Supreme Mariner
So, while you were in there messing with the carburetor, did you clean the main metering jet orifice? It is in the very bottom of the float bowl and must be absolutely, positively squeaky CLEAN.
Did you check the ignition system? Most carburetor problems....aren't.
moose54
i have good spark. yes the motor will restart after it stalls. i dont have to reprime the bulb after it stalls. after i took the carb apart i dip it in a chem bath of carb cleaner and blew it out with air.
moose54
moose54
i believe i found the problem it is the fuel pump.i pulled off the vacuum line off the back of the fuel pump and squezzed the primer bulb and fuel shot out of it. to me it sounds like the diaphram in the fuel pump is bad.could i be wrong in assumming this?
