1963 Glasspar Avalon Restoration
Status
Not open for further replies.
Rockdog97
We just got a 1963 Glasspar Avalon as a restoration boat - it is my wife's moms boat that has been in the family for years, but has not seen water since the late 1980s.
I figured that we could at least get it back to water-worthy, but have no real intention of doing a full restoration, just restore/repair it enough to get it back on the water.
That being said, I'm a bit concerned with the condition of the boat. The floor needs to be replaced, the gelcoat/fiberglass needs a good cleaning, and I'm afraid the transom might need to be replaced.
The engine needs to be replaced as well as the electronics, wires, cables, etc.
Where do I start!?? :confused::confused::confused:
matt167
Re: 1963 Glasspar Avalon Restoration
whether you want it to be or not, it's probably in for a full stringer, transom, deck job. Depending on which motor it is and the condition it is in ( has compression ect... ), it's quite likely cheaply fixable. Very few Johnson/ Evinrude parts are NLA with the exception of electric shift lower unit parts.
Rockdog97
motor is garbage and will need to be replaced.
Stringers I take it are what go under the floor (or deck)? to add support?
chconger
Yes stringers run front to back. They are wood covered in fiberglass in 95% of the time.
Rockdog97
So what would be the best way to take off the deck to expose the stringers? Just cut around where the deck meets the sides? or leave a lip?
Woodonglass
Yes, use a circular saw set to about 5/8" deep and cut with the narrow edge closest to the side. Pry bars, Hammer and Chisels will do the rest. 4 1/2" grinder with a backup Pad and 24 Grit Resin Coated Sanding Discs will do the rest.
Rockdog97
Thanks... I think that will get me started...
boatbeginner1
Like matt167, this will probably be a full restore. You will have fun with the Restore!
Rockdog97
At this point, I'm not really interested in pursuing this re-build.
Mod EDIT: Solicitations are prohibited.
Topic Closed
Status
