1963 Johnson 40hp
doomanmxz99
Went out fishing today and on the way back in hit rock in shallows. Now I have lower unit oil dripping out from prop??? Didnt break anything but it killed motor but she fired right back up. Any ideas?????
Chris1956
Honorary Supreme Mariner
Re: 1963 Johnson 40hp
Sounds like a bad prop seal. Does that motor have the gearcase that splits horizontally? If so, the fix is pretty easy. You might look around for a seal kit
doomanmxz99
I thought it might be the prop seal but dont know if it splits horizontally??? If it dont is it pretty hard???
tashasdaddy
i believe it splits like this.
doomanmxz99
That pics looks like mine. Thanks for the info. Doesnt look to hard or is it?????
freddyray21
not hard at all. seal comes out and new one pressed in. o ring around the housing and I like to use some permatex no 2 around it also.
