1965 Starcraft Holiday
Status
Not open for further replies.
GA_Boater
Re: 1965 Starcraft Holiday
Shove the transom in. That means you started putting her together. Always raises the spirit.
65starcraft
After a few hours of cleaning, and some jb weld.
Nice job with the JB weld is JB weld flexible enough not to crack when spread in that long of a section?I need to do the same thing just curious if you can flex the alumium still?
65starcraft
The aluminum still seems to be as flexible as it was.I plan on sanding it down some and fill in anything that is not flat.
65starcraft
Got the transom bolted in.
the old holes all filled in.
65starcraft
Another fun filled evening of workin on the boat. I got everything sealed up nice with 4200. and primed up the the rest of the transom.
and got the floor cut and dry fit.
barato2
you're flying through that thing! lookin good so far. like the way-retro wheel
FishNmemories
Wow, 65SC...the restoration is coming along great. The transom turned out awesome, looking forward to your finish!!
starcrafter65
Always good to get the floor in - makes walking so much easier!
65starcraft
Got the inside all scrubbed up on sat. afternoon. And today I got the glu-vit on all the rivets and seams.
65starcraft
She all primed up and ready for some paint. I used a coat of self-etching primer then a coat of sandable primer.
GA_Boater
65SC - once the paint starts flying it's all downhill. :D
EDIT - Did the Durafix rods work for ya?
65starcraft
GA_Boater; EDIT - Did the Durafix rods work for ya?[/QUOTE said:
They did not work for me, The transom skin is to thin. before i could get it hot enough i could see it start to warp the aluminium. I ended up just using a metal filler, worked out o.k.
GA_Boater
And it's flyin' nice, too. Thanks for the rod update, or is that downdate?
barato2
and your resto continues to fly......you are really making short work of that hunk o tin
lookin great. thanks for posting the fresh-paint pix, i need those to inspire me to dive into mine.
Status
