1966 chrysler 75hp were do i get impeller kits
Marioleonard
I tryn to figure out were I can get an impeller kit for my motar, and does the impeller kit come with water pump seals and lower unit seal to do everything? thanks
waiddog
Re: 1966 chrysler 75hp were do i get impeller kits
I use Crowley marine for all of my parts for my 76' 75HP Chrysler
jerryjerry05
The posts are old and the original poster probably hasn't been back to see them.
Posting on something older than a month is usually a waste of time??
But thanks for trying to help.
Marioleonard
Hey guys I am here thanks for all the help I got the parts and its running good again
Thanks Again guys you always help
How much oil does my lower unit take I've already put 2 500ml bottles in and still not coming out of top? I have a 1967 Chrysler 75 hp
waiddog
I think its around two quarts. If you still have nothing then I would suggest letting it sit in some water then check and see if there is water in the oil. Might have a leak. Just a suggestion. best of luck! Send some powers my way!! or XXXX
jerryjerry05
I think???They take anywhere from 800ml to 1000ml.Or 24-32 oz.
