I tryn to figure out were I can get an impeller kit for my motar, and does the impeller kit come with water pump seals and lower unit seal to do everything? thanks
Re: 1966 chrysler 75hp were do i get impeller kits
The posts are old and the original poster probably hasn't been back to see them.
Posting on something older than a month is usually a waste of time??
But thanks for trying to help.
I think its around two quarts. If you still have nothing then I would suggest letting it sit in some water then check and see if there is water in the oil. Might have a leak. Just a suggestion. best of luck! Send some powers my way!! or XXXX
