NorthMsRiverRat
Thread starter- Joined
- Apr 9, 2014
- 42
Hey guys and gals. New to the forum but have been using you're expertise to get me through a few repairs i was not so sure about. I know my way around any other small motor but an outboard is totally foreign to me. Here's my problem, I have a '68 Johnnyrude 9.5 horse and I'm trying to replace my water pump impeller. I have the 4 bolts off holding the lower unit on, was able to drop the LU about a half inch which gave me access (VERY limited access) to the coupler with 2 bolts. I have read on these forums that fiddling with the shifter might allow the LU to drop a little further making it easier to get to the coupler, no luck here. I also read that taking one bolt out of the coupler should free the LU, again, no luck. And to make matters worse, I had the bright idea to remove one bolt anyway and dropped it down in the LU! I also disconnected the shifter rod on the top of the motor thinking maybe it was catching something up there only allowing it to drop a certain amount, once again, no luck. So my question to you guys is what am I doing wrong or what in the world is holding this thing on? and once I get it off, how the heck do you get it back together if all I have to work with is a half inch gap?!
Please let me know if I need to be more clear, I can tell you every detail if need be but was trying to keep it short and sweet.
Many thanks to you in advance. I'm sure someone on here can tell me something
