1968 Larson All American
coolbri70
Re: 1968 Larson All American
so its raining today i wanted to work some more on the rear bench seat, i made a backrest out of 1/4 ply made it hollow to be lightweight with a divider as it will double as a speaker box, this i will glass to the platform behind the bench seat and attach padding, i was trying to scrub/polish the gelcoat, noticed the color is worn thru in places, now trying to decide if i should gelcoat or paint it?
coolbri70
backrest/speakerbox1332650364578.jpg1332650318725.jpg
coolbri70
so it rained too much to glass in my backrest so i pulled the wheels of the trailer so i can clean them up and paint them with a fresh coat of white, i got some decent tires saved back at work im off tomorrow so if the paint dries enough i can stop by before they close to mount and balance:) going to paint the fenders blue, the lug bolts blue too;)
coolbri70
i painted stuff and mounted, balanced tires:D1332797830845.jpg
coolbri70
did some painting after removing the rubber that was glued to the sides1332951195917.jpg1332973717629.jpg1332973792004.jpg1332974439473.jpgthen test fit the backrest needs some triming here and there
coolbri70
old pics 047.jpganother before pic 1332973717629.jpgafter
coolbri70
1332974319082.jpgthe bench lid will lift off the locker will be on hinges1332974392887.jpgfrom behind needs trimed then i will glass it in after some grinding
coolbri70
1333319539508.jpg1333319559655.jpg1333319519772.jpg1333319550840.jpg1333319593985.jpgstarted work on backrest install
coolbri70
:Dthanks, i put a lot of work in this, i tend to keep things, been driving the same vehicles for 15 years1333194484160.jpgold pics 058.jpg and do not plan to replace them, so i plan to keep this boat the rest of my life, it suits me, though i may add a hard top, and i may have to modify the truck to handle the towing:rolleyes:
coolbri70
i been practiceing:D
oh thats my Donzi by the way
coolbri70
spent the day at the dmv boat and trailer now legal:D, just need to finish:rolleyes::facepalm:
coolbri70
so today i ground the gelcoat off the outer transom skin it had so many cracks that by the time i ground them all out it was only a little more to finish it off. going to add a layer of glass then new gelcoat, also cleaned up my splashwell repair some, still need to put the drain tube in the splashwell before painting and remount the motor:cool:
coolbri70
1334463007695.jpgmy forearms are itchin
coolbri70
some gelcoat really shows how bad my sanding went guess i sand some more add another coat1334606561971.jpg1334606583606.jpg1334606596356.jpg1334606602600.jpgthe pigment seems to have slowed cure time
