Mastiff_in_Norway
Thread starter- Joined
- May 16, 2016
- 20
My 78 year old father has an old Norwegian built wooden boat and enjoys to go to boat meets. He thought it would be a good idea to have a period engine on it, and that has bitten me in the butt rather hard because I said I'd help him find one. They are very hard to find in Norway, but I found one for him one and a half year ago, and it was supposed to be very good, overhauled by the guy that the then owner had bought it from. We bought it in the fall, after the boat was on land, so we couldn't test it. I also found a kit for converting it to control box use and mounted a control box in the boat. Next spring we tested it and it ran, but very badly. It wouldn't idle at all. After a short while it got worse, and after a trip to a shop where my father lives that was expensive, but not very helpful, my father used another engine the rest of the season. The local shop said that it had a leak at the bottom of the crank case which should be the problem.
I brought the motor home with me (we live around two hours from my father). A neighbour's son is a boat mechanic, and he took pity on it. So earlier this spring the motor was checked more thoroughly. Turned out that it had been overhauled, but wrongly. He tore down the powerhead and found that there leak in the bottom of the crank case was because the hobby mechanic that had done the "overhaul" hadn't used sealant, and he found that the crank and pistons were damaged (crank bearings, and burnt holes in the pistons). Also there were signes that it had been under water. I found a new crank with pistons on eBay for it. He got that in, and thought that it should be the ticket.It still wouldn't go right. The engine stopped after a short while and was very difficult to start again. Also he had to squeeze the bladder when it stopped, so it didn't pull gas correctly. He found that there was a leak in the fuel pump gasket, so he overhauled the fuel pump, which had a damaged membrane and gasket. Of course the brass fittings on the small hose from the fuel pump to the carb disintegrated when he was putting it together again, so that was changed too. And it still won't go right. It now pulls gas as it should, the bladder stays hard, so it seems likely that there is an ignition problem. He has tried and spent far too much time on the thing already, but all that money in parts and his time shouldn't really go to waste.
So the problem still is that it does start, but it stops after a short while, and then it's very hard to start again. Also it won't idle. So you can say that it does run, but very badly. Can somebody please give me a few tips I can take to the mechanic? He works at a Mercury dealer, but they have no manuals for motors that old, and he asked me if I could find out the measuring values for the ignition and prosedures to get it adjusted correctly. I know it's a 1969 from the serial number, and means a Phelon type ignition, not the Phase Maker, which I have read is very infamous! I found a kind of a manual online, but it covers a lot of motor types in one go, so I don't know how accurate it is.
