69 Alumacraft
Thread starter- Joined
- Nov 15, 2009
- 173
The Johnson has a bad power head the Evinrude has all bad motormounts. I pulled the powerhead off the Rude and plan to do the same with the Johnson and either put the good power head on the johnson or start harvesting parts from it. My issue is the cover styles are different and so are the motormounts, I like the sixties sporster looks but it does not look like the Johnson mounts will jive. Also part #37
— 204809 — BRACKET, COVER MOUNT is broken on the rude and the corresponding Johnson bracket is different. I saw one on e-bay for 10$ and some used mounts for 7$ instead of the 50$ they want for new. Should I just suck it up and replace the parts or try to use the ones off the Johnny? The only downside to the 69 cover is it is harder to pull the carb because of the way the bottom cowling is lipped. Any advise or pointers on this adventure appreciated.
