1970 115 Evinrude help!
JRegier
I'm checking over this motor right now, I'm not seeing any difference in vdc when the motor is running or off. I tested the rectifier (checked out ok) and I was wondering if there was a way to test the stator with the motor off.
Forgot to mention; checking for power at the battery.
Bosunsmate
Re: 1970 115 Evinrude help!
you can ohmn it, youl have to look up the values or someone might know.
you really want to test voltage out when its at a good charging rpm though
emdsapmgr
The factory service manuals back in 1970 only used ohms testing. I prefer actual output voltages instead. Try this website: cdielectronics.com They have some excellent troubleshooting information and may have some solid output voltages that you can measure when cranking it over.
