1970 40hp Johnson water pump problem
sparrott
I have a 1970 Johnson 40 horse and im not sure the water pump is working. Can anyone tell me where the water will pump out of to check thanks
SparkieBoat
Re: 1970 40hp Johnson water pump problem
drop the gear case, water pump is at the base of the drive shaft.
smevil
New to this, but have been trouble shooting 1970 evinrude 40 horse for last 2 weeks which I believe is the same engine, and got it back on-line with out spending allot . Just taking things apart cleaning and re-installing, Either way we ran our motor in a large bucket and did not see alot of water coming out, first I believe there to be a thermostat this needs to come to temp before opening, allowing more water to escape out the hole just below the top cowling facing aft. Also a heads up I got a bit of oil in my bucket this concerned me but after talking to the peeps here, they informed me this is normal for our engines, but I still had concerns and water flow through the engine, so to ease my concerns I got the water pump rebuild kit for 28.00 vs. just impeller for 21.00 and changed tho feather seal and o-ring + seals in about an hour first time doing it. This made me feel alot better knowing this is done.
SparkieBoat
I put a new impeller in every motor I get and then change them every few years..they can last a long time..but it only takes one good overheat to ruin your motor..change the gear oil and t-stat also.
sparrott
what hole will the water pump out of if the water pump is working? there is the big hole and right below it 2 small holes or will it come out toward the bottom of the lower unit?
sparrott
ok i took it out for first time today and it was pumping but i thought it was weak but after watching video i think it is good. thanks for the help and video
rrotzetter
so im encountering the same problem and i have talked to the local marina, they seem to think its impossible to get parts for my 1968 40hp johnson, if so were can i find them?
thanks
geoffwga1
They are talking through their hat.You can get most bits right here at i- boats,If they don't have themmthere are plenty of other places,not counting ebay.Just google "outboard parts".
Geoffwga1
oldybutagoody
iboats.com
marineengines.com
seawaymarine.com
thanks
