1970 evenrude triumph 60hp
Kevin 393
hi guys Im thinking on buying this motor the guy that has it said it ran in the spring but kept stalling on him what could this be from and do you think it would cost an arm and a leg to fix this problem . I know it maybe dirt in the carb but any other things you's think or know could cause this thanks guys
Daviet
Re: 1970 evenrude triumph 60hp
See if he will let you take a compression and spark test. Check lower unit for water.
The problem is most likely ign or carbs, normal items for maintaince. Fuel lines could be coming apart on the inside, should be replaced.
These are only a guess, checks should be made.
F_R
Honorary Supreme Mariner
The very first thing to do because it is so simple, is look to see what spark plugs it has in it. If they are still trying to run the surface gap plugs that were originally reccommended, trash them and put in Champion L77JC4 or QL77JC4. That alone has fixed the lousy running on many a motor of that year and size.
If it already has those plugs, there is a virtual laundry list of things that can be wrong with it. I was there when those motors were new and they were state of the art at the time. They also gave me a lot of these gray hairs that I have. There are better motors in this day and age.
I also agree with the previous suggestion concerning the basic condition of the motor. There is no point in beating a dead horse.
Jeff_G
Keep in mind the engine can be plain worn out, it is 40 years old!
Kevin 393
hi guys I got the 60hp motor the guy gave it to me for free !!!! he told me the guy that owned it b4 him did a mod to it and put a oil filled coil on the motor or something to that effect has any one heard of this being done b4 ? Oh and it is an evenrude triumph 1970 motor
Kevin 393
I just did a compression test on the motor and it has 125 psi on all 3 had it running and it stalled out then started it up again and it tried to stall out but I hit the choke and it reved back up so am thinking it is in the fuel or carbs?
