1971 25hp evinrude carb adjustment
870 Expressmag
Cleaning and rebuilding carb on 71 sportster 25hp, what’s the initial setting on low speed needle?
lindy46
Try 1.5 turns out for the slow speed (top) and 3/4 turns out for the high speed.
Honorary Supreme Mariner
High speed jet is a calibrated hole.----No adjustment.-----Why are you cleaning the carburetor ?----What is the motor doing / not doing ?
870 Expressmag
Motor fired when I bought it a few weeks ago, guy had it running in a barrel but he kept pumping primer which told me fuel pump was weak, got it home and wouldn’t start. So I got a fuel pump kit and carb kit, fuel pump diaphragms were deteriorated, and when I got carb off the bowl was dry, low speed needle packing was split so tore it apart to rebuild
