I'm looking for a little help with with a Johnson 60ESL71C. 60hp, Hydro-Electric shift, 1971. I have no spark and it appears to be stuck in forward. I know it's an electric shift and the default is forward so I am kind of assuming the two problems are related.
I did a little probing with a multi-meter at the buss and everything appears normal except the connections to a little black box on the right side (as you are viewing the engine from behind). It says Motorola Automotive, but the model number is scratched out. It has 3 wires to the bus that appear to be burned near the bus to the point that the insulation is cracked and bare wire is exposed. The tan wire has 12V from the bus and the other two are dead. A forth wire travels to the spark advance arm and then disappears under the flywheel. No voltage there either.
1. What is the black box and is this related to the other problems?
2. How can I test it?
3. Any tests or diags I should perform for spark problem.
I'm familiar with outboards and do a lot of work on Mercs of that era. I'm a Merc guy, but I don't hold a grudge. I have been posting on the Merc board since I found these forums. A little Karma would be nice.
Thanks
Thanks
