Ok First post. K just got this engine off ebayabout 3 weeks ago...been running it off and on for about 2 weeks.. its been progresivly sounding worse, as-in there was a metalic ringing..ding ding type of noise.. but not to loud..so i tested her out first time on saturday. turned her on reved her for a bit..still hearing the metalic dinging.so i tried putting it in reverse to leave the dock and the engine stalled. Tried it a few more time same thing kept stalling. so we manually turned the boat so we could drive forward. gave it a lil gas, put it in gear and went off. it wasnt but 40 yds till the heat horn in the controll unit went off non stop till i turned it off about 30 seconds later. towed it home and fist thing checked the oil in the lower unit seemed fine. dropped the lower unit. found the impeller frail and 3 wings broken off with another barely on. plus the little metal wedge thing that hold the impeller was out so the impeller dont think was spinning much.i ordered a new impeller today.
1. Did i mess up anything bad by testing out the engine with the broken impeller.
2. Is there anything else i should check on. So it wont over heat.
Thank you any advice will be appreciated.
