1971 Johnson 9.5 dissassembly question
joho5
How do you take the plates off that are above the lower unit but below the cowl and powerhead. The green sides that case the motor in.
Is it a simple procedure or is there some sort of parts linked to this?
I am wanting to repaint these.
thanks
ezeke
Re: 1971 Johnson 9.5 dissassembly question
It is quite complicated because of the need to disconnect almost all of the linkage plus the front panel. At a minimum, you will need both the factory service manual and the parts manual.
Here is a picture posted by Iwombat
attachment.php
iwombat
That essentially equates to a powerhead removal.
wildmaninal
Good luck is all I can say. There are so many steps to taking that motor apart, that's why a service manual would be good to have. I have the same type of motor in the shed that I managed to get apart after these guys gave me some direction, and I used the brp website diagram for some help. I haven't even bothered putting the motor back together and it was/is a running motor, I just had to get the drive shaft out of the powerhead. Those motors are a pain.
joho5
I will probably just leave it alone. I will paint it while attached. Id like to paint the insides, but will probably just leave it alone.
thanks though for the help
