I noticed something that is a bit inconsistent on mine due to play in the shift linkage and knob.
When this motor is in neutral or reverse, most of the time there is pin that lifts into place to limit the throttle. Is that correct? or is that only supposed to lift into place when in reverse? Sometimes it blocks the throttle in neutral and sometimes not. If it isnt, how do you adjust this linkage and / or tighten it so it doesnt have so much play. Its on the screw tight in the gearcase and it seats fine in the slots down by the prop. Is there something I can adjust / tighten up in the motor casing by the power head?
thanks
thanks
