Re: 1972 1150 115hp engine observations
EricKems said:Did you use the high idle lever and choke when you tried to start it?
Bob_VT said:Inlines typically leak gas like that. Could be as simple as a float that needs adjustment (just getting to the float is time consuming).
AMD said:There is a topic in the FAQ which describes some of the items that should be looked at to revive a motor that has sat for a long while. The fuel system, including the supply lines and bleeder lines should be inspected and replaced. Carbs should be cleaned with new gaskets, needles, seats. Inspect the plugs/wires. Clean out the distributer cap and inspect for cracks. Follow the timing recommendations also listed in the FAQ, aiming for 21° max. Don't overlook the requirement to replace the water pump impeller, and change the gear oil.
I too have a '72 Glastron with a '72 1150. I would be very interested to know what model Glastron you have. Any pics?
Good luck.
Click to see large image
monk-monk said:i have a '72 glastron w/ 115hp inline six. got the boat w/ motor for a little labor. had to replace internal wiring harness and alt. stator due to burned wires. tried to start it but didn't fire. when motor is lifted for transport or storage i see a small amount of fuel out of the choke plate area. rumor has it the boat sat for a long time, restored to service w/ tune-up. what i'm i in for and where to start?
