1972 7.5 mercury not getting fuel
fishinwithmercury32
I have just rebuilt the carb and replaced the check valves in the fuel pump along with all gaskets. Im not getting a continuous pull on the gas/oil mix. It runs for a second when i put gas/oil directly into the carb but wont stay running. Also, when i take off the hose from pump to carb and crank, there is no gas spitting or pumping. Only when i squeeze the bulb.
I'm at a loss. Any help would be much appreciated.
Thanks,
Mason126
Re: 1972 7.5 mercury not getting fuel
Thanks,
I am not being smart here, but did you put the gaskets and diaphram back in the right order? Good Luck
Mason126
no apology needed. yea there in there right. triple checked that.
I am having the exact opposite problem. My 7.5 will only start in the wide open position and it screams. It will idle down but very rough!!
I was at a Merc repair shop today and he stated that if you spray into it runs but stops right away it is most likely carb issues.
