Re: 1972/73 Merc 402 40 hp Thunderbolt
Would like to get everthing in the picture..
- 66843T BRACKET, COIL MOUNTING > NLA, but probably still usable.
- 75692 THERMOSTAT-143 > $10.75
- 27-62386001 GASKET, THERMOSTAT > $1.50
- 27-66847 GASKET,COIL MOUNTING BRACKET TO BLOCK > $3.20
- 25-64872 GROMMET,POPPET VALVE > $1.76
- 65848 CARRIER, POPPET VALVE > $1.73
- 86596 POPPET, RELIEF VALVE > $4.98
- 24-66852 SPRING, COMPRESSION-POPPET RELIEF VALVE > $9.69
- 339-5288T2 IGNITION COIL ASSEMBLY, COMPLETE > $65.99 need 2
- 84-813715A1 LEAD ASSEMBLY, SPARK PLUG (HIGH TENSION) > $20.82 need 2
All prices are Mercury list prices( from Mercruiser parts .com) .
All part numbers are for a Mercury 402, but please verify the number against your model
I have listed most of the parts on the picture ( not bolts/nuts/washers), NOT all parts needs replacement .
You might add a water pump kit ( or just the impeller ) too .
Arne Kjetil
