1972/73 Merc 402 40 hp Thunderbolt
mikeinnc40
Anyone know where to get this part or does anyone have one?
Came off a 402 40 HP Mercurey Outboard.
Any help would be appericated.
Thanks Mike
Laddies
Banned
Re: 1972/73 Merc 402 40 hp Thunderbolt
There are several parts there, which do you need? If you need them all check marinas for a donor motor.
mikeinnc40
Would like to get everthing in the picture.. but as it looks only the left side when standing facing the plug wires look bad,engine got a bit hot on me.
thanks for your help.
mikeinnc40@gmail.com
Droll
  • 66843T BRACKET, COIL MOUNTING > NLA, but probably still usable.
  • 75692 THERMOSTAT-143 > $10.75
  • 27-62386001 GASKET, THERMOSTAT > $1.50
  • 27-66847 GASKET,COIL MOUNTING BRACKET TO BLOCK > $3.20
  • 25-64872 GROMMET,POPPET VALVE > $1.76
  • 65848 CARRIER, POPPET VALVE > $1.73
  • 86596 POPPET, RELIEF VALVE > $4.98
  • 24-66852 SPRING, COMPRESSION-POPPET RELIEF VALVE > $9.69
  • 339-5288T2 IGNITION COIL ASSEMBLY, COMPLETE > $65.99 need 2
  • 84-813715A1 LEAD ASSEMBLY, SPARK PLUG (HIGH TENSION) > $20.82 need 2
All prices are Mercury list prices( from Mercruiser parts .com) .
All part numbers are for a Mercury 402, but please verify the number against your model :) .
I have listed most of the parts on the picture ( not bolts/nuts/washers), NOT all parts needs replacement .
You might add a water pump kit ( or just the impeller ) too .
Arne Kjetil
