racerham
Thread starter- Joined
- Jun 23, 2018
- 1
Hi All, New in this part of the forum.
I picked up a Starcraft 16' for fishing and crabbing in the bays on the north oregon coast. It needed work, ran like crap, but the compression is good, 120 on all cylinders. Spark is good. It's an electric shift and the first time out it would go into gear with a huge clunk and a jerk from the idle being too hi.
I cleaned the carbs and it made a world of difference. Now it idles at 1000 rpm, in forward gear, in the water. No load is 1300 rpm or so.
The idle needs to be high because when putting it into reverse the engine bogs. It bogs to the point that setting the idle properly (700 rpm) in forward, the motor dies when it goes into reverse. Bogs much worse than when going into forward. It acts like it's under a heavy load in reverse, but under a normal load when in forward.
Is this normal? or where should I look? I'm stumped.
Thanks for any help you can provide..
