Beautiful work Dyce! I am in Phoenix and so I am with you on the heat and dry conditions. Although we are about to hit our second 100+ day today with a topper at 105-6 in the next couple days. :-( I know you are about 10 degrees cooler down there. Is the plan to keep this boat or sell it? For me on my first, I finally had to start telling myself that I am learning on this one, but for you, this is a third boat. My gut says by that point I would be wanting to do a boat that had everything I wanted. If you plan on keeping it, as it is a third boat then resale considerations are not really a worry. But, maybe waiting a month or two or three to finish it would be worthwhile to save up for the power you need. Way you are rocking this out, would be tempting to ignore the power for the sake of getting on the lake. Plus you mentioned ocean use, do you need the extra power there?
Hey there Mark, I promise not to let the project and the thread die. It's just been so hot here in Tucson and now with the storms rolling through everyday it makes it kinda rough to get any work done. I've been doing a little here and there and getting some parts together. Also been running some numbers and lay out for all of my electronics.( tends to take a little time) what part of the country are you in and how far along are you?Hi john I was following your posts with much interest since I also have a 1972 Thunderbird Formula 233. Mine has twin Mercruiser 165hp. My father was the second owner and prior to him passing away he gave it to me. It has sat for 12 years and I finally have enough money to start the restoration project. This will be my first and I am looking forward to all the headaches. Keep giving updates.
Re: 1972 Formula 233 Project
So Im finding myself pondering again over what type of power to put in this soon (I Hope) to be awesome boat. If I had the funds (and the wifes approval) I would have planned on twin 250s or 300 outboards. Thats not in the cards for this one. Trying to keep formula number one an i/o and keep the feel of an old classic boat with a little modern twist here and there. Not looking to break any speed records but would like to cruise around 25-30 and would be happy with a wot of 45-55 on flat silky windless water. LOL. I have the old tired 302 and the merc 888 outdrive. It could easily be rebuilt. Im thinking maybe a punched out 351 windsor and an alpha 1. Any comments? Suggestions? Pros? Cons? Im open to ideas but just keep in mind I'm not crapping out gold bars every morning….
Hey there, sorry for the slow reply. I've seen the cabin decks pulled out in one piece but don't have to do it one this project. My rear deck were soft so I opted to pull everything and I will just redo with glass and rejelcoat when done. Both the cabin and rear deck are fiberglassed in so it may be a slow process of pulling it out whole. I only had foam in my gas tank area also. I do plan on adding foam where I can for floatation and sound. I did notice when I was pulling the deck that there was a thick bead of resin on top of my stringers. I hope that helps.Hi john I have a few question about your 233. Friday I moved my 233 to my house after sitting for 12 years. I am in the process of striping the cap and removing the enigines. The tank is already out along with the foam. I plan on removing the 112 bolts holding the cap and some how taking it off. First ?. I only see foam in the fuel tank bay did yours have any foam else where. Second ?. I see you cut your deck out in pieces. On mine it has two separate pieces or modules. The front cabin floor and the larger rear deck floor just like yours. I would like to keep these intact. Do you think it's possible to remove these things whole. If it is possible I know it will be a lot of work and both are going to be very heavy. It looks like the sides are glues or bonded somehow to the stern and sides. If I can cut along these edges and come up with a way to lift it out is there any type of bond under the deck to the stringers. I would show you pics but still can't get photobucket to work.
I'm thinking about a 351 Windsor. I have a local shop here willing to do a new build for me with install for a smoking deal. I won't be ready for it till jan or fen next year. But I'm still open to ideas. As I said before I'm not looking to win any races, I'm looking for reliability.Nice boat, looking forward to seeing your progress! one other thing to throw out there, a 383 stroker, lots of torque, and the low cost of Chevy small block parts. If you are keeping it long term, biting the bullet and putting what you want in it is always the best way to go....painful today, but you'll be happy later on.
Even though a 351W is a small block Ford, don't forget to take into consideration that it's very different than a 302. 351W has a taller block deck, the heads sit higher and make a wider Vee, that makes a different exhaust setup necessary. The intake valley is wider and may not work properly with your throttle and shifter setup. The carb will sit at a different position as well and you're going to need a properly matched 4bbl for it.
The engine is physically larger than a 302 because of the deck height, you want to make sure it will physically fit into your boat when fully outfitted with manifolds, risers, carb.
These are all considerations I made when I wanted to put a 351w in my truck. Even with all the automotive components available, I decided against it because of the changes I would have to make. When it came down to swapping the engine, the mustang 302HO made more power than a 351w and similar torque. I just installed that using all my old components and I got the massive power increase I needed.
